GIT stops working a while after started
Hi
Have used this tool for many years now, never with bigger problems, until now. First to mention, all drivers are latest (2.28 and 3.8.2.0). After P3Dv4.5 is started up and aircraft loaded, i start the GIT (PMDG 777-200/Majestic Q400). Everything then looks fine, 3 green lights and all my Goflight modules works fine. But, after a short while, the modules stops working. When i then open up the GIT, opens the Status Tab, i got RED-YELLOW-RED lights. I try to close the program for restarting it, but the GIT program window freezes. Unable to close the program unless i go CTRL-ALT_DELETE. So, what have i tried :
I first uninstalled GIT and GF program from the Programs in Control Panel. Then i deleted the Documents/Goflight.....folder. Searched computer for any GF-files, those where also deleted. I then re-installed the programs to ONE folder, on my M:drive. I run all programs as admin, but problem is still there. Even if i just opens up the GIT program when no other programs are running, it freezes. I try to close it, but message is : "Program not responding". Then CTRL-ALT-DELETE.
I really don't understand what have happened. This is a computer i only use for P3D, nothing else. Therefore, no changes have been done unless windows update aso.
Please/hope you can give me a solution that fixes this, thanks
Brgds
Tore S
Brgds
Tore S
