MCP & DIO
I seem to be having issues since I have deleted my Sim PC which had originally win7 running with all my goflight kit successfully and reinstalled my prepar3d v4.5 onto win10 which all went according to plan.
The issue I'm having after configuring stuff again I'm finding my Goflight MCP works perfectly with pmdg737 i.e. when I turn a knob it reacts perfectly in the cockpit but I'm getting no display on the MCP
All leds are dead although if I restart the GF interface tool it lights up for a couple of secs before the aircraft loads then goes off again.
Also my GF DIO card has the exact same issues if I turn on my autobrake RTO dial on my cockpit annucuator doesn’t light up but turns on when I look at the virtual cockpit.?
I'm at my wits end with it as i can't think of what I have done differently from my previous install on win7 although it was I while back I done it so maybe I have missed some thing
I’m using the latest - GoFlight Interface Tool P3Dv4 64Bit Version 3.8.2.0
And prepar3d - 4.5.14.34698
Hopefully someone can point me in the right direction as I know it can't be anything much that I've missed as both MCP & DIO board do appear to work when I look at the virtual cockpit and I’ve made no hardware changes only reinstalled win10 instead of win7
I presume my other GF hardware with led displays will be the same but I haven’t plugged the rest in yet as I thought I would try and resolve these first.
Craig
  • It can be two things. Windows Power Management has not been disabled on your GIT devices and related hubs and USB ports. If that doesn't fix it, read the GoFlight drivers readme file and find the section regarding Windows8Fixer.
