737 EVT_MPM_AUTOBRAKE_SELECTOR works except RTO?
Anyone else having issues sending custom '0' to EVT_MPM_AUTOBRAKE_SELECTOR and having it be received by the 737?
Values 1,2,3,4 work GREAT. For some reason 0 just doesn't want to trigger.
  • Should have shared details - I'm still using P3Dv4
  • Ok, I seemed to figure it out in case others want to use this fix - instead of using CUSTOM as the connector action, I switched to ROTATE_REVERSED only for the RTO action, and that seems to work! All the rest of the buttons are mapped to the actual custom values on the rotation switch. Cheers!
