GIT P3Dv5 issues MCP pro
Hi all ,
long time since i have been here and need help. After having issues i reinstalled GIT P3D 64bit and now i have 3 green lights and no errors in log but i have no display or input control from my MCP using PMDG aircraft. GIT shows up in addons and i am able to restart but display and inputs are still not there. Have changed USB ports and no luck. Checked GF Driver/control panel and MCP is there and if activated it lights up my MCP. What i think maybe the problem is a file might be missing in P3D its self as i remember having to be prompt to allow GIT file to be installed on previous installs, but not sure what i am looking for. If someone can help it would be greatly appreciated. On another note i tried to download a fresh copy of GF drivers but their link seems bugged as it download but there is no file there. If someone has a dropbox link or a fix that too would be great.
  • 00:27:36 GoFlight Connection Starting.....
    00:27:36 SimConnect Connection Starting.....
    00:27:36 GoFlight Connection Started
    00:29:50 SimConnect Message Processing Started
    00:29:50 SimConnect Connection Started
    00:29:50 Aircraft Connection Starting.....
    00:29:53 WinSock: Connected To localhost On Port 27015!
    00:29:53 LUA Processor: Started!
    00:29:57 SimConnect: Event Received: Start
    00:29:57 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
  • ok found error with fsuipc in log if that helps
  • OK problem resolved , had too enable and disable MCP pro a few times in GIT and it came back to life . It kept clearing device 0 for some reason but i managed to make it stay this time
  • Ok my problem is solvable to a degree, but its being a pain having to restart and click selectionsmultiple times . Problem GIT starts MCP Pro with Device 0 not selected and Enabled. I select Device 0 and Enable it as it loads it Disabled and restart GIT only to have it return to previous state. Rinse and repeat until it decides to work than either it loads with error and only allows input but no return to my display. Now for PMDG and supported aircraft this does not happen so much but others like Leo,s MD 80 more common. Is there a way to make sure when i load GIT that it locks my MCP Pro as Device 0 and Enabled. This has been the cause of most of my issues , i have tried reinstall,s to different directories/folders,admin rights ect and most other suggestions and tips from guide and FAQ.
  • If you have set it, it will stay enabled for the aircraft you enabled it for. It's aircraft specific. It may look DISABLED, but it only shows its state when you actually pick a Device number.
