GIT Installed, but not opening properly?
I have installed and run Setup for a purchased version of GIT MS2020. However, I'm obviously doing something wrong?
Every time I double click (either the program or the desktop shortcut) to open the program, I just get a message that the program is already running, but no GIT program screen is displayed. That said, there is a brief "flash" on screen as though the program is running, but not staying "open" so I can't access it. Nothing shows as open in the Task Manager as well.
The same situation occurs whether I'm trying to run the program with/without MSFS 2020 loaded and running.
I know this is a stupid question, but can someone tell me what I should be doing to correct this problem?
Many thanks,
Brian
Many thanks,
Brian
I reinstalled and although its still a bit buggy opening (it needs to be forced close via the task manager between each use), I can now successfully call it up both outside and within the sim,
Brian
