MSFS GIT cannot startup
After release 4.4.0.0 everytime i run GIT obtain 2 errors like this:
Unable to Load Aircraft Configs:'.' hexadecimal value 0x00, is an invalid character. Line 1, position 1
The graphic interface si loaded, 3 status led are green but all tabs are disabled - please look at troubleshooting attached file
Someone had the same problem? Can you help me?
The "pollypotsoftware-flightsimio-module" is in the path C:\Users\Giuseppe\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\Packages\Community
Thank you
Thank you
If nothing is there, you will have to restore from a backup or restore from the Backup directory in Documents\GoFlight Interface Tool\Backup renaming the files from .bak.
18:35:24 GoFlight Connection Starting.....
18:35:24 SimConnect Connection Starting.....
18:35:25 GoFlight Connection Started
18:35:25 SimConnect Message Processing Started
18:35:25 SimConnect Connection Started
18:35:25 Aircraft Connection Starting.....
18:35:25 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:35:25 SimConnect: Event Received: SIM, 1
18:35:25 SimConnect: Event Received: PAUSE, 0
18:35:26 WinSock: Connected To 127.0.0.1 On Port 27016!
18:35:26 LUA Processor: Started!
18:35:26 Aircraft Connection Started
18:35:26 Simconnect Version: 11.0.62651.3
18:35:26 Aircraft FullName: Asobo_C152
18:35:26 SimConnect: Exception Received: OUT_OF_BOUNDS
18:35:29 SimConnect: Exception Received: OUT_OF_BOUNDS
18:35:32 SimConnect: Exception Received: OUT_OF_BOUNDS
18:35:35 SimConnect: Exception Received: OUT_OF_BOUNDS
18:35:38 SimConnect: Exception Received: OUT_OF_BOUNDS
