question on DREDataRefs.txt and DRE Mimic Mode
If I understood the DRE Mimic Mode in the Starting & The Status Tab documentation the file DREDataRefs.txt should be created automatically.
When I have a look in my aircrafts directory (C:\Games\X-Plane 11\Aircraft\B737-800X) I have no DREDataRefs.txt. I do not have the DataRef Editor Plugin installed.
When starting GoFilight Interface Tool X-plane, the DRE Mimic Mode is operational, I can see the green tick shown in the X-Plane status area.
It also says scanning X-plane, which takes a considerable time every time I launch (or re-launch the interface).
Do I something wrong, or is this normal behavior or is there an issue somewhere ?
  • Yes it should. Try running GIT as administrator in case its a security issue.
    If the plane is complex, it can take a while as its reading all the files to find custom commands and datarefs.
    I tried running GIT as administrator, same behavior.
    • a green checkmark apperars next to DRE Mimic Mode
    • It says Scanning Files (above the DRE Mimic Mode)
    • After a couple of minutes under AIRCRAFT it checksmarks Commands.txt, OBJ.DataRefs, ACF DataRefs, DREDataRefs and OBJ Commands
    • no DREDataRefs.txt is created in the aircraft directory, only DRE.txt
    This happens every time I start or relaunch GIT. Meaning I always need DRE Mimic Mode and it will scan everytime.
    Log
    20:18:34 GoFlight Connection Starting.....
    20:18:34 X-Plane Connection Starting.....
    20:18:35 GoFlight Connection Started
    20:18:36 X-Plane Connection Started
    20:18:36 Aircraft Connection Starting.....
    20:18:36 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
    20:18:39 WinSock: Connected To localhost On Port 27015!
    20:18:39 LUA Processor: Started!
    20:18:39 Aircraft Connection Started
    20:18:39 Synchronising Switches & Selectors .....
    20:18:39 Synchronising Switches & Selectors: Waiting for X-Plane .....
    20:19:55 LvarNamesUpdated!
    20:19:55 Creating Bespoke Vars
    20:19:55 Bespoke Vars Created
    20:19:55 Importing Bespoke Variables
    20:19:55 Bespoke Vars Assigned, Importing Bespoke Events
    20:19:55 Bespoke Events Temp Imported
    20:19:55 Bespoke Events Imported
    20:19:55 Loading Aircraft Settings
    20:19:55 GetXMLConfigData
    20:19:55 GotXMLConfigData
    20:19:55 Loading Power
    20:19:55 Loading MCPPRO
    20:19:55 Loading EFIS
    20:19:55 Loading P8
    20:19:55 Loading T8
    20:19:55 Loading RP48
    20:19:55 Loading MESM
    20:19:55 Loading WP6
    20:19:55 Loading LGT
    20:19:55 Loading LGT II
    20:19:55 Loading GF46
    20:19:55 Loading GF45
    20:19:56 Loading TQ6
    20:19:56 Loading DIO
    20:19:56 Loading GF166
    20:19:56 Loading SECM
    20:19:56 Loading Joysticks
    20:19:56 Clearing Displays
    20:19:56 Reset Data
    20:19:56 Aircraft Settings Loaded
    20:19:56 Calling Aircraft Changed
    20:19:56 Aircraft Changed
    20:19:57 XPlane: Event Received: Sim State 1
    20:20:00 Global LUA Event Running
    20:20:00 Global Aircraft LUA Event Running
    20:20:00 Synchronising Switches & Selectors Complete
  • Are you sure you don't have the DRE plugin running, because that is the only other thing it could be?
