WP-6 assignments switched around.
I am having a problem where my WP-6 enabled 0 and enabled 1 seemed to have gotten mixed up. What I mean by that is that all the functions on the left WP-6 now work on the right side WP-6, and vice versa. I read in a previous post that
The GoFlight SDK determines the devices device number and I have no control over that. You can manually edit the settings.xml file to swap the device id's around when it happens.
Can you give me a little more detail on how to change the Id's in the settings.XML? I generally use notepad.
Rob
Rob
Thanks again.
Rob
