MCP not working correctly suddenly
my MCP has stopped working correctly with the 737 NGX.
The lights of the Hardware Buttons are sometimes not matching the lights inside the PMDG.
For example.....i set LVL CHG and then i activate V/S. Inside the PMDG the light is then switching from LVL CHG to SPEED. On the MCP suddenly both lights are lighting up. Several similar failures do also occur.
As far as i can remember the only thing i have changed is the Write and command delay sliders.
If this has something to do with it...what are the Standard values ?
Thank you !
Regards Andi
  • edited January 2015
    If you have the MCP PRO with firmware A25 you can set MCP PRO sliders both to 0. If not, write is 50, cmd is 65.
    Best wishes
