PMDG 777 Prepare3D Problem
Installed the recently released PMDG 777 in P3d V2.4   The GoFlight MCP Pro has operable switches and rotaries, but only zero indicators, when accessed with the latest interface tool.  The latest GoFlight drivers are also installed.  The MCP Pro operates normally with the  PMDG 737 NGX within the same setup .
 Does Version 2.1.7.0 fully support the PMDG 777 in Prepar3D V2.4?
    I'm still waiting for a development copy of the 777. In the mean time you could check that the file <your P3D directory>\PMDG\PMDG 737 NGX\737NGX_Options.ini contains:
    [SDK]
    EnableDataBroadcast=1
    Ensure Prepar3D is not running when you do this.
  • Steve,
      That entry did not exist in the 777 Options ini.  After I added it, the 777/MCP interface is fully functional......Thank You.
    Robert
  • edited February 2015
    It's probably due to not having "Enable for Prepar3d" ticked in the Settings tab.
     The "Enable for Prepar3d" option was ticked.. The FSX was not.
    It was present in the 737 ini file due to a previous installation of the Tool.
  • Ok, that's clearly a bug then.
  • Confirmed as a bug and is fixed. Wait for release 2.1.9.0 as the fix didn't make the latest Beta.
