New version available but no details here
Hi Steve. GIT advised me today a new version is available but I can find no mention here of what it changes.
Ray (Cheshire, England)
  • Chane log is here. https://www.pollypotsoftware.org.uk/vanillaforums/index.php?p=/discussion/8/change-log-goflight-interface-tool
    But I would recommend to wait with the update. It is faulty for me in P3D.
  • Thanks Andi. It appears to be for MSFS only. As I don’t have that sim I see no need to update. If the advisory message is going to keep appearing that will become annoying. Can it be turned off?
  • I think this version is actually for P3D as well since it states
    ALL:
    - Improved parameter checking in Lua extensions to avoid crashes.
    Hopefully I can do a roll back because the new version us not working for me :(
  • I missed that, thanks Andi. Let’s see what Steve says. I have no issues with the current version in P3D v5.2 HF1.
  • Bug is fixed, you can download a new version now. 64Bit only. Will update the other versions over the next hour or so.
  • Thanks Steve.
  • Hi Steve. I've just downlaoded and installed GIT 64-bit for P3Dv4/5. I then rebooted the PC but on launching GIT I still get a message a new version is available.
    The version I'm running is v3.8.2.0. It's installed to C:\GoFlight. The exe was last modified on 02/12/2020. Something has gone wrong I suspect.
  • The new version should be 4.5.1.2.
    For P3D v4/5? I downloaded from the list of versions and chose P3D v4/5. Maybe you’re referring to MSFS.
  • Try uninstalling first and make sure the setup file has the correct version in its filename. There are 3 versions for P3D, so make sure you click the right icon if you have more than 1 installed.
  • Hi Steve. Will do but why three versions for P3D? A 32-bit version for v3 and a 64-bit version for v4 and v5. Why a third one?
  • A handful of people couldn't get the 64bit version to work with v4 and v5; probably just a placebo, but it solved their issues.
  • I had 3 GoFlight executables, one more than necessary. I uninstalled both entries in CP and installed the 32-bit one for P3Dv3 and the 64-bit one for P3D v5. Now running 4.5.1.2 and all appears well.
