GIT Xplane issue with config tabs not showing values
I got an issue with GIT XPlane version 2.0.16.3.
When I fill in commands or bespoke events in the Switch event config tab the are not shown except those starting with sim/...
The same is true for the Light/Disp data values..
When using Bespoke Variables for Light Light/Disp data values it shows not the name but ex. Bespoke Var 1.
But when I use a command or dataRefs as Light Light/Disp data that are not sim/... it stays empty like laminar/....
* Did already remove aircraft
* Did remove the GIT folder in documents and recreated modules config
* Did remove GIT and re-installed
Any ideas ?
  • Not sure what is going on. I will need to test at my end and see if a bug has crept in that you are the first to report.
  • I have done a quick test with the MCP Pro and it kept the Bespoke Events and Bespoke Variable selections.
    Does this issue only happen with a certain aircraft or certain Goflight modules?
  • edited April 2022
    Happens on all modules. Seems to be on multiple planes (ZIBO and Levelup)
  • It might be a security issue. Try running GIT as administrator.
  • Found the cause, after I got the same issue in my new computer.
    When setting some values (time) to low in the setting tabs.
    After I restored default values fields were again visible.
