Unable to get the SendKey or SendKey* to work with Ctrl + F11 sequence.
P3D V5.3, this used to work in V5.2.x so not sure why it isn't working now. I have HiFi ASP3D setup for Ctrl+F11, works fine when triggered manually in P3D but not via Detective. Any suggestions?
  • Hi Rob,
    Not sure, the code hasn't been touched in years. I'll do a test my end and come back to you.
  • This is working now, seem my "Run As Admin" fix post. Cheers, rob.
  • Is there any way SendKey could be used without having to use GFConfig for the iFly 737? I use Ctrl+F11 for Weather Services request and Ctrl+F10 for Ground Services request across all aircraft I fly but with PMDG and iFly I can implement on my common GF-P8.
  • You have lost me there: "Is there any way SendKey could be used without having to use GFConfig"
  • Hi Steve, happy new year, hope you had a good healthy holiday.
    I'll clarify, when using iFly or PMDG, there is no "detective" (blocked) and hence no way to create bespokes for Sendkey Ctrl+F11 that I can assigned to a P8 button. I'd have to install Goflight's provided GFConfig and setup the Ctrl+F11 sequence there ... I'm trying to avoid installing GoFlights provided software.
  • The new platform opens up PMDG for use with Detective, so GIT will get this.
  • You've been busy, can't wait to try it out.
