GFIT with msfs 2020
I have installed the gfit according to the directions into the community folder and confirmed it is there. I installed the MS store version because that's where I purchased it. When I try to create a LVAR using the detective it will not work. As an example, I was trying to program a toggle switch to control the beacon on the 787. I used the detective and found which lvar was being used when I pushed the button on the aircraft. As i go to set up the lvar it is there correctly. But when I hit the test bespoke event, the detective shows it is working by sending the exact information but the beacon will not work on the aircraft. I am sure I am doing something wrong but I have programmed several events in P3Dv4 and they work. Any ideas?
