FBW A320 ECAM Switches
Hello, does someone has an idea how to build a bespoke event for the FBW A320 ECAM Control Panel System buttons? I tried to assign the system buttons to GF buttons, but only the button light will illuminate. I've ask this at FBW discord but got no answer so far. The LVAR A32NX_ECAM_SD_CURRENT_PAGE_INDEX set to 6 for example will illuminate the APU button but will not switch to the page itself. If I'm using A32NX_ECAM_SFAIL set to 6 nothing happens, then I have used additional the ECAM SD INOP APU LVAR set to 1 to initiate the switching, then the APU page will come up for a half of a second only and then the normal page will be shown. APU is here for example same for Bleed, ELEC and so on.
Can anybody give me a hint how to solve this problem? Thank you in advance best regards Ralf
