How to create a IF ELSE
I created a bespoke command that sets interior cockpit panel lights to a predefined value or to 0.
I want to turn on/off the panel lights with 1 push button.
Panel brightness increases or decreases with a 0.05 value.
As I'm never sure what panel brightness is set (I can always change it in the virtual cockpit) I want to turn it off the brightness is different from 0.
When brightness is 0 I set my predefined values.
But the following will not work to turn on the lights, because when I'm at task 5, panel_brightness[0] will be different from 0 due to task 1 to 4. So I need a a else, or I should be able to store panel_brightness[0] first in a var that I can reuse.
How can I solve this without using a switch and have to create a case for every of the 21 values.
  • You have to use labels and goto tasks when using if tasks to divert control flow. Alternatively use switch, case and endswitch.
