GFIT long loading time
Hello, I have the problem that GFIT has sometimes a long, long loading time, all LED's on status tab are green but the RH (Aircraft) did not flicker and GFIT is not connected and MSFS is blocked (no response). This is not related to SU9, have the problem since longer time, one time I have to shuitdown the PC and start all new, one time it takes 10 minutes until GFIT is fully connected, one time it takes 10 seconds with the same AC and the same scenery and I have no idea why. If it takes longer the log stays at e.g. Aircraft FullName: FlyByWire_A320_NEO and nothing will happen. If the GFIT is started, everything is working normal, all GF modules without faults. Has anybody an idea what I can do to get acceptable loading time?
Best regards Ralf
«1
  • Hi
    Sorry for not responding; I've been ill for the past month and only now just getting back into work.
    Are you running the latest version, as this issue was resolved?
  • Hello Steve, yes I'm using newest GFIT software and the problem still exist, I follow every time the same startup procedure and sometimes GFIT is running within seconds, sometimes it stucks and take forever, log file stops here:
    17:18:03 GoFlight Connection Starting.....
    17:18:03 SimConnect Connection Starting.....
    17:18:04 SimConnect Message Processing Started
    17:18:04 SimConnect Connection Started
    17:18:04 Aircraft Connection Starting.....
    17:18:04 GoFlight Connection Started
    17:18:05 WinSock: Connected To 127.0.0.1 On Port 27016!
    17:18:05 LUA Processor: Started!
    17:18:05 Aircraft Connection Started
    17:18:05 Simconnect Version: 11.0.62651.3
    17:18:05 Aircraft FullName: Generic
    17:19:46 SimConnect: Event Received: Start
    17:19:46 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    17:19:46 SimConnect: Event Received: SIM, 1
    17:19:46 SimConnect: Event Received: PAUSE, 0
    then after a while proceeding with:
    17:24:19 LvarNamesUpdated!
    17:24:19 Awaiting Late Lvar Registrations (30 Second Timeout)
    and so on - then GFIT is available
    As you can see, it takes five minutes in this case for GFIT until the program is running. It's not related to a special aircraft or location or SIM setting.
    Do you can help in this matter?
    Best regards
    Ralf
  • Steve, it would be nice to answer my quenstion or give me a hint, the problem still exist, sometimes it loads within seconds, sometimes within 5-7 minutes, sometimes never. everytime fresh starting my PC no other programs running. What can I do to find a solution. Best regards Ralf
  • Does it make a difference starting GIT after the aircraft is loaded?
  • no, it makes no difference, loads sometime fast sometimes long, sometime never
    Best regards Ralf
  • Is there a default aircraft that causes this, so I can use your config files to test. If so let me know which one and zip up Documents\GoFlight Interface Tool and attach it to this thread.
  • I'm using GFIT only with FBW and Fenix A320 at the moment, no other or default aircrafts are assigned or in use.
    Best regards Ralf
  • Unfortunately I have still the problems to start GFIT. Either the program is not starting and MSFS will freezing or it started with long long loading time. This happens everytime when MSFS was not used last days and it is independent which AC I'am using. not happy with this situation. After unsuccesful start the PC must complete switched off and on again and hopefully GFIT then is working, but sometimes not...
    Best regards Ralf
  • I would suggest renaming Documents\GoFlight Interface Tool so that GIT starts clean. It will mean having to do your configs again.
  • to config all again is not an option at the moment (not enough time to do). It seems that I have to wait sometimes a little bit longer until the Goflight modules awaking... Best regards Ralf
  • what does it mean in log: ....Synchronising Switches & Selectors: Waiting for SimConnect ..... and then GIT it is waiting for 10 minutes or forever, MSFS is frozen since GIT was started.
  • see the logfile:
    14:55:57 GoFlight Connection Starting.....
    14:55:57 SimConnect Connection Starting.....
    14:55:58 SimConnect Message Processing Started
    14:55:58 GoFlight Connection Started
    14:55:58 SimConnect Connection Started
    14:55:58 Aircraft Connection Starting.....
    14:55:59 WinSock: Connected To localhost On Port 27016!
    14:55:59 LUA Processor: Started!
    14:55:59 Aircraft Connection Started
    14:55:59 Simconnect Version: 11.0.62651.3
    14:55:59 Aircraft FullName: Generic
    14:55:59 Synchronising Switches & Selectors .....
    14:55:59 Synchronising Switches & Selectors: Waiting for SimConnect .....
    14:57:22 SimConnect: Event Received: Start
    14:57:22 PMDG SDK option is OK in FS2020
    14:57:22 SimConnect: Event Received: Aircraft Type Changed
    14:57:22 SimConnect: Event Received: SIM, 1
    14:57:22 SimConnect: Event Received: PAUSE, 0
    14:57:22 SimConnect: Event Received: VIEW, 2
    14:57:22 GoFlight Connection Starting.....
    14:57:22 SimConnect Message Processing Finished
    14:57:23 SimConnect Connection Starting.....
    14:57:23 Creating Bespoke Vars
    14:57:23 Bespoke Vars Created
    14:57:23 Importing Bespoke Variables
    14:57:23 Bespoke Vars Assigned, Importing Bespoke Events
    14:57:23 Bespoke Events Temp Imported
    14:57:23 Bespoke Events Imported
    14:57:24 SimConnect Message Processing Started
    14:57:24 Synchronising Switches & Selectors: Waiting for SimConnect .....
    14:57:24 GoFlight Connection Started
    14:57:24 SimConnect Connection Started
    14:57:24 Aircraft Connection Starting.....
    14:57:24 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    14:57:24 SimConnect: Event Received: SIM, 1
    14:57:24 SimConnect: Event Received: PAUSE, 0
    14:57:24 SimConnect: Event Received: VIEW, 2
    14:57:25 WinSock: Connected To localhost On Port 27016!
    14:57:25 LUA Processor: Started!
    14:57:25 Aircraft Connection Started
    14:57:25 Simconnect Version: 11.0.62651.3
    14:57:25 Aircraft FullName: PMDG 737-600
    14:57:25 SimConnect: Exception Received: NAME_UNRECOGNIZED
    14:57:26 Send Control Data: Too Many Retries
    14:57:27 Send Control Data: Too Many Retries
    14:57:28 Send Control Data: Too Many Retries
    14:57:29 Send Control Data: Too Many Retries
    14:57:31 Send Control Data: Too Many Retries
    14:57:32 Send Control Data: Too Many Retries
    14:57:33 Send Control Data: Too Many Retries
    14:57:34 Send Control Data: Too Many Retries
    14:57:35 Send Control Data: Too Many Retries
    14:57:37 Send Control Data: Too Many Retries
    14:57:38 Send Control Data: Too Many Retries
    14:57:39 Send Control Data: Too Many Retries
    14:57:40 Send Control Data: Too Many Retries
    14:57:41 Send Control Data: Too Many Retries
    14:57:42 Send Control Data: Too Many Retries
    14:57:43 Send Control Data: Too Many Retries
    14:57:44 Send Control Data: Too Many Retries
    14:57:45 Send Control Data: Too Many Retries
    14:57:46 Send Control Data: Too Many Retries
    14:57:48 Send Control Data: Too Many Retries
    14:57:49 Send Control Data: Too Many Retries
    14:57:50 Send Control Data: Too Many Retries
    14:57:51 Send Control Data: Too Many Retries
    14:57:52 Send Control Data: Too Many Retries
    14:57:54 Send Control Data: Too Many Retries
    14:57:55 Send Control Data: Too Many Retries
    14:57:56 Send Control Data: Too Many Retries
    14:57:57 Send Control Data: Too Many Retries
    14:57:58 Send Control Data: Too Many Retries
    14:57:59 Send Control Data: Too Many Retries
    14:58:00 Send Control Data: Too Many Retries
    14:58:01 Send Control Data: Too Many Retries
    14:58:02 Send Control Data: Too Many Retries
    14:58:03 Send Control Data: Too Many Retries
    14:58:05 Send Control Data: Too Many Retries
    14:58:06 Send Control Data: Too Many Retries
    14:58:07 Send Control Data: Too Many Retries
    14:58:08 Send Control Data: Too Many Retries
    14:58:09 Send Control Data: Too Many Retries
    14:58:10 Send Control Data: Too Many Retries
    14:58:11 Send Control Data: Too Many Retries
    14:58:12 Send Control Data: Too Many Retries
    14:58:13 Send Control Data: Too Many Retries
    14:58:14 Send Control Data: Too Many Retries
    14:58:16 Send Control Data: Too Many Retries
    14:58:17 Send Control Data: Too Many Retries
    14:58:18 Send Control Data: Too Many Retries
    14:58:19 Send Control Data: Too Many Retries
    14:58:20 Send Control Data: Too Many Retries
    14:58:22 Send Control Data: Too Many Retries
    14:58:23 Send Control Data: Too Many Retries
    14:58:24 Send Control Data: Too Many Retries
    14:58:25 Send Control Data: Too Many Retries
    14:58:26 Send Control Data: Too Many Retries
    14:58:27 Send Control Data: Too Many Retries
    14:58:28 Send Control Data: Too Many Retries
    14:58:29 Send Control Data: Too Many Retries
    14:58:30 Send Control Data: Too Many Retries
    14:58:31 Send Control Data: Too Many Retries
    14:58:33 Send Control Data: Too Many Retries
    14:58:34 Send Control Data: Too Many Retries
    14:58:35 Send Control Data: Too Many Retries
    14:58:36 Send Control Data: Too Many Retries
    14:58:37 Send Control Data: Too Many Retries
    14:58:39 Send Control Data: Too Many Retries
    14:58:40 Send Control Data: Too Many Retries
    14:58:41 Send Control Data: Too Many Retries
    14:58:42 Send Control Data: Too Many Retries
    14:58:43 Send Control Data: Too Many Retries
    14:58:44 Send Control Data: Too Many Retries
    14:58:45 Send Control Data: Too Many Retries
    14:58:46 Send Control Data: Too Many Retries
    14:58:47 Send Control Data: Too Many Retries
    14:58:48 Send Control Data: Too Many Retries
    14:58:50 Send Control Data: Too Many Retries
    14:58:51 Send Control Data: Too Many Retries
    14:58:52 Send Control Data: Too Many Retries
    14:58:53 Send Control Data: Too Many Retries
    14:58:54 Send Control Data: Too Many Retries
    14:58:55 Send Control Data: Too Many Retries
    14:58:56 Send Control Data: Too Many Retries
    14:58:57 Send Control Data: Too Many Retries
    14:58:58 Send Control Data: Too Many Retries
    14:58:59 Send Control Data: Too Many Retries
    14:59:01 Send Control Data: Too Many Retries
    14:59:02 Send Control Data: Too Many Retries
    14:59:03 Send Control Data: Too Many Retries
    14:59:04 Send Control Data: Too Many Retries
    14:59:05 Send Control Data: Too Many Retries
    14:59:07 Send Control Data: Too Many Retries
    14:59:08 Send Control Data: Too Many Retries
    14:59:09 Send Control Data: Too Many Retries
    14:59:10 Send Control Data: Too Many Retries
    14:59:11 Send Control Data: Too Many Retries
    14:59:12 Send Control Data: Too Many Retries
    14:59:13 Send Control Data: Too Many Retries
    14:59:14 Send Control Data: Too Many Retries
    14:59:15 Send Control Data: Too Many Retries
    14:59:16 Send Control Data: Too Many Retries
    14:59:18 Send Control Data: Too Many Retries
    14:59:19 Send Control Data: Too Many Retries
    14:59:20 Send Control Data: Too Many Retries
    14:59:21 Send Control Data: Too Many Retries
    14:59:22 Send Control Data: Too Many Retries
    14:59:24 Send Control Data: Too Many Retries
    14:59:25 Send Control Data: Too Many Retries
    14:59:26 Send Control Data: Too Many Retries
    14:59:27 Send Control Data: Too Many Retries
    14:59:28 Send Control Data: Too Many Retries
    14:59:29 Send Control Data: Too Many Retries
    14:59:30 Send Control Data: Too Many Retries
    14:59:31 Send Control Data: Too Many Retries
    14:59:32 Send Control Data: Too Many Retries
    14:59:33 Send Control Data: Too Many Retries
    14:59:35 Send Control Data: Too Many Retries
    14:59:36 Send Control Data: Too Many Retries
    14:59:37 Send Control Data: Too Many Retries
    14:59:38 Send Control Data: Too Many Retries
    14:59:39 Send Control Data: Too Many Retries
    14:59:40 Send Control Data: Too Many Retries
    14:59:41 Send Control Data: Too Many Retries
    14:59:42 SimConnect Message Processing Finished
    14:59:42 GoFlight Connection Starting.....
    14:59:42 SimConnect Connection Starting.....
    14:59:43 GoFlight Connection Started
    14:59:43 Global LUA Event Failed!
    14:59:43 Global Aircraft LUA Event Failed!
    14:59:43 Synchronising Switches & Selectors Complete
    14:59:43 SimConnect Message Processing Started
    14:59:44 SimConnect Connection Started
    14:59:44 Aircraft Connection Starting.....
    14:59:45 WinSock: Connected To localhost On Port 27016!
    14:59:45 LUA Processor: Started!
    14:59:45 Aircraft Connection Started
    14:59:45 Simconnect Version: 11.0.62651.3
    14:59:45 Aircraft FullName: Generic
    14:59:45 Synchronising Switches & Selectors .....
    14:59:45 Synchronising Switches & Selectors: Waiting for SimConnect .....
    I have no idea how to proceed....
  • That looks like you are not running the latest GIT WASM module or its not even present in your Community folder. You can download the latest version from your account and manually install if necessary.
  • unfortunately this is not the solution, installed everything new and checked in community folder and also in developer mode, it seems to be depending last used AC status (engine off or C&D or all systems running) which causing the problem. But I can not see a rule or legality between last used AC status and the next GFIT start procedure. Best regards Ralf
  • Hi Steve - still the same "Too Many Retries" - what can I do?
  • Hi Steve, are you still active here?
  • What version of GIT are you running?
  • Hi Steve, I'm using 4.7.3.2
  • The waiting will continue until the aircrafts virtual cockpit is shown.
  • no sorry, that is not the solution, if GIT is started after AC is fully loaded, I have the same behaviour, sometimes it takes seconds, sometimes 10 minutes, sometimes it will not start at all and MSFS is freezed. Pleasae check the possibility that it has something to do with last AC status, maybe GIT can not be configured well if for example last status was all off and during next start AC is set on the RWY. At the moment here it is a coincidence, will it work or not... Best regards Ralf
  • I think because you are the only user who has this issue, it may be related to corrupt config files. Can you rename Documents\GoFlight Interface Tool and then start GIT which will now have a blank config. Then try the PMDG with say the MCP (remember to enable it in GIT, then restart GIT).
  • I will do this and come back after checking each module. Best regards Ralf
  • Hi Steve, with new GIT in documents folder and only MCPPro activated it also has longer loading time, the logfile says (in german language):
    19:53:43 WinSock: Connection Failed: ... no connection... 127.0.0.1:27015
    19:53:43 LUA Processor: Connect Exception - Unable To Connect!
    19:53:43 Aircraft Connection Started
    19:53:43 Simconnect Version: 11.0.62651.3
    What can I do to check the connection denied part and why is port 27015 in use now, see my previous post there was port 27016 in use?
  • Change "localhost" in Documents\GoFlight Interface Tool\Lua Config.txt to your PC's IP address. Restart GIT and the Flight Sim to pick up the change.
    The port is correct.
  • I've added the IP adress to LUA Config, after next MSFS start GIT waits 2 minutes for SimConnect - is this as it should ? and further there is SimConnect exception (NAME_UNRECOGNIZED), then GIT is available. GIT start was initialized after complete loading of PMDG in MSFS at the gate. see logfile, best regards Ralf
    13:31:40 Simconnect Version: 11.0.62651.3
    13:31:40 Synchronising Switches & Selectors: Waiting for SimConnect .....
    13:33:11 SimConnect: Event Received: Start
    13:33:14 Aircraft FullName: PMDG 737-600
    13:33:15 SimConnect: Exception Received: NAME_UNRECOGNIZED
    13:33:15 Send Control Data: Too Many Retries
    13:33:38 Send Control Data: Too Many Retries
    13:33:41 Global LUA Event Running
    13:33:41 Global Aircraft LUA Event Running
    13:33:41 Synchronising Switches & Selectors Complete
  • I have just done a fresh install of GIT with FS2020 set to load the PMDG as default. I renamed Documents\GoFlight Interface Tool, created a new directory for GIT (Documents\GoFlight Interface Tool) and copied Lua Config.txt into it which had localhost updated with my IP Address.
    I then started GIT and then started FS2020. There were no delays and no Send Control Data errors. Can you do the same and report back.
  • Hi Steve, I've done as advised, downloaded actual GIT and installed and copied LuaConfig.txt into... with PMDG as start AC nearly the same behaviour, GIT is waiting for simconnect, see shorted log.file below - it seems to be the 24'th unsolved mathematical problem according to David Hilbert... as you can see the software is waiting three minutes for simconnect and then has a lot of "Too Many Retries". What can I do?
    17:22:29 GoFlight Connection Starting.....
    17:22:29 SimConnect Connection Starting.....
    17:22:30 SimConnect Message Processing Started
    17:22:30 GoFlight Connection Started
    17:22:30 SimConnect Connection Started
    17:22:30 Aircraft Connection Starting.....
    17:22:31 WinSock: Connected To 192.168.2.102 On Port 27016!
    17:22:31 LUA Processor: Started!
    17:22:31 Aircraft Connection Started
    17:22:31 Simconnect Version: 11.0.62651.3
    17:22:31 Aircraft FullName: Generic
    17:22:31 Synchronising Switches & Selectors .....
    17:22:31 Synchronising Switches & Selectors: Waiting for SimConnect .....
    17:25:21 SimConnect: Event Received: Start
    17:25:21 PMDG SDK option is OK in FS2020
    17:25:21 SimConnect: Event Received: Aircraft Type Changed
    17:25:21 SimConnect: Event Received: SIM, 1
    17:25:21 SimConnect: Event Received: PAUSE, 0
    17:25:21 SimConnect: Event Received: VIEW, 2
    17:25:21 GoFlight Connection Starting.....
    17:25:21 SimConnect Message Processing Finished
    17:25:21 SimConnect Connection Starting.....
    17:25:22 Creating Bespoke Vars
    17:25:22 Bespoke Vars Created
    17:25:22 Importing Bespoke Variables
    17:25:22 Bespoke Vars Assigned, Importing Bespoke Events
    17:25:22 Bespoke Events Temp Imported
    17:25:22 Bespoke Events Imported
    17:25:22 GoFlight Connection Started
    17:25:22 SimConnect Message Processing Started
    17:25:23 SimConnect Connection Started
    17:25:23 Aircraft Connection Starting.....
    17:25:23 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    17:25:23 SimConnect: Event Received: SIM, 1
    17:25:23 SimConnect: Event Received: PAUSE, 0
    17:25:23 SimConnect: Event Received: VIEW, 2
    17:25:24 WinSock: Connected To 192.168.2.102 On Port 27016!
    17:25:24 LUA Processor: Started!
    17:25:24 Aircraft Connection Started
    17:25:24 Simconnect Version: 11.0.62651.3
    17:25:24 Aircraft FullName: PMDG 737-600
    17:25:24 Send Control Data: Too Many Retries
    17:26:23 Send Control Data: Too Many Retries
    17:26:26 Synchronising Switches & Selectors Complete
  • I think it can only be one of two things. You are not loading the GIT WASM module, or are loading an old version.
    Enable developer mode in FS2020. Then on the dev menu, select Tools and then Packages. Confirm you can find pollypotsoftware-flightsimio-module listed as version 1.0.1. Check the package: path next to it (you will need to drag the divider line next to it so see the full path) and then using Windows Explorer goto that location path and confirm the modules date is 27th January 2023 ( (inside the modules subdirectory you will find the wasm module).
  • Hi Steve, in Dev Mode readout shows for Pollypot Module: 1.0.1 / Patch 1.29.30, timestamp in community folder for FlightSimIOModuleWASM.wasm is 27.01.2023 14:13. Best regards
  • OK, I suspect the PMDG SDK is being turned off. Can you check the following with GIT and FS not running:
    To enable the data communication output, you will need to open the file
    737_Options.ini that is located in the 737 persistent storage folder.
    For Microsoft Store distribution, this folder is located at
    %LOCALAPPDATA%\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\Lo
    calState\packages\pmdg-aircraft-737\work\.
    For Steam distribution, this folder is located at
    %APPDATA%\Microsoft Flight Simulator\Packages\pmdg-aircraft737\work\.
    Once this folder is open, add the following lines as required to the bottom of
    the file:
    [SDK]
    EnableDataBroadcast=1
    Try again, if still no good, check the above again and see if it has been turned off.
