Go Flight interface face will not load up
I’ve been using this since it came out with my PMDG 737 and 777 and works flawlessly but lately I set the PMDG 737 or 777 ready to go in the sim P3d version 4.5 and it won’t load .The sim connect
light goes green but the other 2 are red and it just spins and spins and will not load up .Searched and no luck finding a solution .Incidentally I’m seriously thinking about getting FS2020 ,is everything gonna work fine with my PMDG’s and the go flight interface tool ? Thanks Louis. —Alberta
  • Hi
    Sorry for not responding; I've been ill for the past month and only now just getting back into work.
    It sounds like the GFDev.dll file is missing in GIT's program directory. It's part of the GoFlight drivers.
    Post your log, if you still have issues.
    I plan to add support for the PMDG 737 in FS2020, but I understand there is no longer an PMDG SDK, so it may not be possible.
  • Update: Found a way to enable the SDK and have 3 greens. Will test with hardware tomorrow.
  • Great news! With a few minor code tweaks, everything appears to be functioning OK with GoFlight gear. I will release it tomorrow as I need to update the installer to add the SDK options.
  • Thanks a pile Steve ,your always there for us ,but I removed p3d completely, and moved to fs2020. I put in the latest 2.28.0 go flight conf tool , its in the control panel but says its not installed . When I open the conf.tool fs2020 is ticked but in the program location box it says' Not Installed 'and i have no idea where to install it . My sim is in a 4 tb drive called "F"
  • GoFlight does not support MSFS 2020. You need to use the latest GIT version just uploaded.
