The new software to fix PMDG 737 on MSFS is partly working but not perfect
I have three Go-Flight panels. The MCP autopilot, the SECM switch panel, and the LGT II. The SECM switch panel appears to work correctly but it is the only one in the new software that shows a working Default button. The LGT does not work at all and the default button is greyed out. The MCP does change the settings in the aircraft but remain on 0 on the MCP itself, the default button on GIT is also greyed out. I don't know if I'm going wrong in setting the GIT up but I'm not getting the choice to press the Default button as I normally would. What do I need to do now?
  • Quit and restart both FS2020 and GIT to get the MCP working as sometimes the data won't come down when the SDK has first been enabled.
    The MCP and LGT auto configure so there are no Default buttons needed. Make sure the devices are enabled.
  • New version just uploaded should fix your issues.
    I am not able to download the new version, only x-plane-version ist downloadable.
    Best wishers
    Peter
  • phecht said:
    Best wishers
    Peter
    I have reset your download count.
