I started working on a config for the FBW.
But, its a big job, and takes a lot of time detecting/checking/testing/repeat.
What I do generally is write a Bespoke event that checks the state of a variable and based on its value, take appropriate action based on current value, and I include TOGGLE as part of the event name.
I find that type of Bespoke event covers many of the actions I want to allocate to my GF panels.
Occasionally Ill need a specific setting, so I write another Bespoke event to either change a value and then call the TOGGLE Bespoke event, or just duplicate the toggle event and cut out the bits that I need =just for a specific setting.
With the current version of GIT, Its not that easy to export snippets of code or specific events to then merge into your existing setup.
If this were possible, it would mean it would be much easier to share specific Bespoke events, and to work collaboratively on building a config for a specific aircraft.
I'm happy to assist/work with you if you are interested in sharing discoveries/ideas, and somehow, the code we generate.
Ohlen
A32NX_FCU_ALT_INCREMENT_TOGGLE
Is there a way to input an event if you cant find it in the list of events.
