WP6 Lights not working FS2020
So every since maybe the fourth MSFS 2020 update my light do not work. The button part of them work but no lights.. They all light up when testing... Any idea what has changed or is this FS2020 Asobo just breaking things as usual??????
Jeff R
  • Do they light when you use identify? Have you checked that power management has been turned off?
  • Yes they work when Identifying . "Have you checked that power management has been turned off?" what do you mean here?
  • Just done a quick test with the TBM 930 using parking_brakes with brake_parking_position, on, 1 with the colour Red and it worked fine.
    Can you check the colour has been set for each button.
    Power management is the settings on the USB hubs, ports and devices that suspend the device when not in use.
    You could try using GIT with a clean config by renaming Documents\GoFlight Interface Tool, in case something is corrupt.
