When a device no longer exists bespokes get wiped out on GIT start
Not using the import wizard, using the import from SECM tab. Exception occurred for device GFDEVHWTYPE_GFSECM 0 0 8 EVENT_OFF - Sequence contains no matching element. The export was done with 4.5.1.2 (p3d v5 64bit), but when I try to import I get this error?
I've attached the exported file.
Digging further, it seems to be missing my BespokeEvents.xml so I opened up Detective and Imported my A2A bonanza bespokesevents.xml (assume this loads the variables also) and then did an import on SECM and it worked, no error and my controls mapped. Re-imported all my other mappings/xmls files.
Digging more, it looks like the root of this issue is I had removed two 166's from my PC (no longer connected) and when GIT tried to load them and gave me a warning they didn't load, it proceed to wipe-out the entire BespokeEvents for the Bonanza!! Yikes!
Soooo, my suggestion is to NOT wipeout the all the aircraft bespokes if there is a missing GF device.
