FlightSimIOLua.exe opens and not responding
I'm using GIT with MSFS. When I run GIT (with admin privileges), it opens a FlightSimIOLua.exe window which not responses, but the GIT window works fine and connects.
Is this a known issue? Is not affecting the use of GIT but it's really annoying.
I ran FlightSimIOLua with and without permissions after loading MSFS2020 in Windows 11 and in both cases the app remains not responsive.
After killing FlightSimIOLua, I open GIT and it will load both (GIT and FlightSimIOLua) without any issue.
So far I have to run GIT, and kill FlightSimIOLua so everything works.
Killed FlightSimIOLua and closed GIT, opened it again and now is working.
Really weird.
- Opening GIT wit will open the GIT Window, a FlightSimIOLua window with the full path on the title which stops responding, but also a FlightSimIOLua in the system tray. The one on the system tray works fine.
If I just leave the FlightSimIOLua nonresponding window, everything works, but I have an annoying window.
I can kill the FlightSimIOLua window which is not working and close GIT. Once closed I open GIT again and now everything works fine, no FlightSimIOLua with full path window opens.
I uninstalled the older version and installed the new version GoFlightInterfaceToolFS2020_Setup_4_7_3_0
I have no changes from the older version.
I have the same problem on both FS2020 and XP12 version.
Do you mean in the Documents/GoFlight Interface Tool directory? I dont have a file with that name.
This output window is not actually FlightSimIOLua which is running minimised in your notification area, but it is created and opened by FlightSimIOLua.
I suggest if you see the black window, simply minimise it, do not attempt to close it, and everything should work OK.
I will investigate why it is now visible and attempt to find a way to hide it when it starts up.
Also, if GIT won't shutdown, click on the FlightSimIOLua icon in the notification area so the window with the aircraft picture appears and then close this window.
Thats exactly what happens. Hope you can find the reason you have that second black window.
Thanks for all your help
Peter
