GF-MCP PRO:
I started having trouble with the ALTITUDE turn knob. When I turn it nothing happens. If I move the knob on the FSX aircraft panel the numbers show up on the MCP. I tried it on several aircraft and it's always the same. All the other knobs and switches work OK on the MCP. Do you think it's a faulty MCP? Thanks.
WILLDREX
Yes. It sounds like the rotary encoder is failing or needs cleaning. If you are comfortable with electronics you can clean or replace it yourself or Goflight will repair it for a charge. I would contact John at Goflight for help.
