GIT FS2020 start but MCP PRO don´t work
I have read all the forum abaut the problem but I don´t have a solution to it
There are no lights on the MCP PRO when I start MSFS 2020.
I have three green lights on the GIT FS2020 (interface), it shows the correct aircraft pmdg 737-700,
In the Interface is everetihng correct but the MCP don´t work.
I have a hub energy and win11
I really dont know why it is not working.. And I trayed evereting.
Any help please?
João
  • Have you enabled the MCP PRO in GIT?
    Do the controls work, only the displays do not?
    Has the SDK options been set in the 737_options.ini file. The file should contain these entries and if not, add them:
    [SDK]
    EnableDataBroadcast=1
    The file is normally located in either:
    AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\Packages
    AppData\Roaming\Microsoft Flight Simulator\Packages
    AppData\Local\MSFSPackages
    You will need to restart GIT and MSFS after the change.
    Please post your GIT log, if the problem continues.
  • edited January 2023
    hello steve
    About enabling MCP via GIT. I didn't change any settings. How can I know if it is enabled or not?
    I returned my Win11 to Win10, because I thought it might be some program conflict, but in Win10, even after reinstalling MSFS, MCP didn't work either. All lights are green and loading PMDG 737 in GIT but notthing in MCP PRO
    About the MCP, it's not working at all, it's not just the MCP and display lights that don't work, the commands don't work either.
    I ran "MCPProChkA25" and MCP is OK. It's not a problem with the hardware,
    PMDG's "EnableDataBroadcast" is also correct "=1".
    I'll check the LOG in GIT and post it here
    Thanks for the help so far
    João
    With FS2020 running and the PMDG aircraft selected; on the GIT MCP Pro tab, pick Device 0 from the drop down and then select ENABLED. Quit GIT and then restart GIT and it should work OK.
  • It worked!!
    Great, thank you so much!
    Joao
