MCP pro , LGT and EFIS not working
Hi after new update my MCP Pro nor LGT nor EFIS are recognized meaning they are not highlighted for me to select, before the update everything was working fine, I have read others having same issues and my pmdg broadcast is set to 1, I can not activate device as it does not allow me to select, I have restarted my devises but no luck, can some one help me get my Goflght hardware working again, only my T8 and 166 is working even my p8 is also not working (just noticed) Help please
  • If they are not identified on the Status tab of GIT it is indicating a hardware/Windows issue. Have you tried a different USB port/hub?
  • I have not as this was all working perfect before the update, but I can try swapping them out hopfully that doesnt make things worse.
    Thanks and I will report results once I have a chance to try this.
  • All good thank you and it was one of my usb hubs that went bad, changing my modules to different usb ports fixed the issue.
    thanks again.
