Problem with Bespoke START event
Ive set up a number of Bespoke Events, each to set an instrument control to a specific setting.
Ive also setup a START Bespoke event, so on loading of the aircraft in MSFS, I call each of the other bespoke events (after a sleep of about 2000 to make sure the 'aircraft' is settled and ready to accept setting LVars and calling SimEvents.
I've noticed that calling the Bespoke events as part of START doesnt seem to work reliably.
If I do a test execution to one of the Bespoke events ( in this case its to open certain cabin doors), this works perfectly.
But if I call that Bespoke event as part of START, it doesnt seem to execute correctly (doors dont open as I expect).
As a test, I copied each of the specific LVar and Event commands from the Bespoke Event and pasted them into START (IE coded the commands directly, instead of calling the Bespoke event (which runs the same commands)) and those individual commands as part of START work as expected.
There seems to be an issue calling bespoke events in series from START.
Any ideas what might be causing this and can it be fixed?
Can you test by simply running GIT without using Detective and confirm the issue remains.
