Send an event o a control using var as parameter
I`m trying to send an event using the following code
Degrees =ipc.readDBL(0X02B00)
ipc.control(66042,Degrees)
Where 066042 is K:HEADING_BUG_SET and 0X02B00 is the offset for PLANE HEADING DEGREES GYRO
This works in FSUIPC7
but I get the following error
Error: ...S\GOFLIGHT INTERFACE TOOL\LUA\ASOBO_CJ4\_HEADING_BUG.LUA:1: attempt to index a nil value (global 'ipc')
I also tried
sendcevt("K:HEADING_BUG_SET", 035) where 035 would then be replaced by the offset to test but I get an error as well
Error: ...S\GOFLIGHT INTERFACE TOOL\LUA\ASOBO_CJ4\_HEADING_BUG.LUA:1: sendhevt: C++ Exception Thrown - Insufficent Number Of Parameters. One Required.
If we figure the Sendcevt, then what do I use for getlvar to get the offset of degrees?
  • Use the SendVar task which will send a Simconnect event using the value of a specified variable.
    Both the Event and variable you are using are standard Simconnect so SendVar will work fine.
