configuring GIT for G166 radios
I need help using GIT to configure my GF166 radios. No matter what I set the GF166 do not respond (no lights, actions). The GIT identify button does nothing?????? MCPRO, LGTII, etc. doesn't respond either.
Please help.
Ken W.
Please help.
Ken W.
Also GF166's are notorious for locking up (its a hardware issue and nothing to do with GIT). You can search the forum for various work arounds people have done to stabilise them.
1. Open FS2020/select dahr930- in cockpit
2. Open GIT
3. IMPORT 930 zip file. loads is successful.
4. GREEN lights on
No response from any modules (no lights,actions or aircraft response) ??????
Repeated the process but used DEFAULT FS option. No affect. No modules respond.
Tried manual programming. No response.
Please help!
Ken W.
Is there a solution to these issues?
1. GF-ATC module not listed in GIT.
2. LGT-II module not listed?
3. After programming in GIT MESM does nothing?
Kenw
If that doesn't work, confirm the GF166 lights up when plugged into the USB port or when the PC boots up. If it doesn't try another USB port. If that doesn't work, you may have faulty hardware.
Let me know the outcome of the above and we can move on to the next steps.
GF-ATC is not supported.
LGT-II is supported.
As for the MESM, confirm its enabled. If so, let me know how you have configured it so I can check the config.
Ran Windows8 fixer. GF166 lights up when usb connected
GF166 - No identify light, no action after programming manually or importimg asobo 166 xml /zip files
MESM - no responses
SECM - Some switches work, not all
LGT-II - not listed in GIT tabs
Running TBM930 in fs2020. GIT setting is ASOBO_TBM930. GIT status lights are green.
If I need other aircraft settings files I can"t locate them. Only zip file I have is ASOB tbm930 downloaded from your site.
Thanks for helping!
Ken W.
kenneth1051@gmail.com
The MESM will need configuring for it to do something.
If not all switches in the SECM are working, its probably because the aircraft in use has not been designed to respond to the events the SECM has been configured with. You would need to use Detective to determine what events the aircraft uses and reconfigure the SECM as necessary.
If the LGT is not appearing in GIT, then its either faulty or you have it plugged into a USB port that is not functioning.
All this has nothing to do with GIT file locations.
Ken W.
I bought this from Amazon. Xiatiaosann 2 Pack 2 Port USB 2.0 Rear Panel Expansion Bracket.
It connects to USB2 Header on my mobo. No modern mobos have USB2 ports so you have to adapt. Providing your mobo has USB2 Headers you’ll be fine.
Then I bought a powered USB2 hub (backward compatible USB3) should be okay. Plug your GoFlight units into the hub that’s plugged into one of the ports on the expansion bracket.
All my units work perfectly including two GF166s.
Ray (Cheshire, England)
