PMDG B737 landing light switches as cluster
Hi Steve!
first of all many, many thanks for your help to my recent problems. Windows11, P3Dv4.5, PMDG Boeings, Engravity Interface and GIt are now working perfectly fine. So here is my first question out of working with GIT.
Is it possible to create an event cluster myself?
You may know the 4 landing light switches of the PMDG 737 and the guard frame, which moves all the 4 switches together and that's the action, which I want to be covered by one switch on a GoFlight T8.
Switch position ON(1) guard frame and the four switches should move to ON position and stay there; the LED on the T8 should light up. Moving the T8 switch to OFF (0) position guard frame and the 4 switches should move to OFF position and stay there. The T( LRD should be switched off.
I just found possibilities to move each element itself but not as a cluster.
regards
Georg
regards
Georg
When sending each event, make sure there is a short Sleep of around 50 m/s, otherwise some of the events may not work.
You could have one script/Bespoke Event that toggles them on or off by reading the current switch position and sending the necessary left or right click with the events or have 2 scripts/Bespoke Events, one that turns them all on and the other that turns them all off.
Georg
