How to programm correctly button control for system anunciator in PMDG B737?
Hello all,
I'm using P3Dv5 and the B737 from PMDG.
I want to assign the press on the system-annunciator to one of the GF-P8 buttons. I'm using the EVT_SYSTEM_ANNUNCIATOR_PANEL_LEFT and 'MOUSELEFT'. The problem is that this simulates only the press on the system annunciator w/o releasing it.
When I press the button in the simulator with the left mousebutton the annunciator gets released as soon as I release the mousebutton.
I'm not able to programm the button in the way that the system-annunciator gets also released when releasing the GF-P8 button or simply pressing and releasing the system-annunciator in one press on the GF-P8 button.
As far as the Fire_WARN and MASTER_CAUTION buttons are concerned, it works well with 'MOUSELEFT' or 'ONOFF'.
How I have to 'programm' the system-annunciator in the correct way?
Thank you for your support.
Greetings
Detlef
  • That is strange as you normally emulate what you do in the cockpit. Have you tried MOUSECLICKTOGGLE?
