GF TQ6 Advanced Reverser Levers
Running P3DV5, Windows 10 64bit, PMDG 737 A/C. Unable to make the reverser levers respond to the reverese thrust position, all other functions work correctly. I have updated the GF Interface Tool to latest version and loaded the PMDG 737 throttle configuration. On selecting Reverse Thrust the two levers on the sim throttle box 'Twitch' but refuse to respond any further. I have discovered that pressing Fn Key F2 will select reverese and the sim levers respoind although I have no idea how this key was assigned to Reverse. I have tried various things and searched the internet to no avail. Be grateful for some advice please.
  • Reverse thrust won't engage unless the sim thinks the thrust levers are fully throttled back. You need to tweak the settings of the 737 levers so that they report 0 thrust lever position to the sim even though they may not be fully back or twitching. What are you using to configure the levers?
  • Steve. Apologies for not responding, didn't realise you had replied, was expecting a notification. anyhow, I recall recalibrating my GFTQ6 Advanced and it has been fine until now. I have raised a separate request for this new problem..
