All goflight modules work but lights and displays only worked for one day.
I am finally figuring out how to use this software and it’s working fantastic with the exception of the lights and displays aren’t working anymore. The first day I had the software, I set it up for the PMDG 737 in MSFS 2020 and it worked just like it did in MSFS 2004 and I did a good long flight. I even built a box to mount all my modules in to sit on my desk. I then set up the modules for the Caranado Cessna 337 and did a good long flight. All the lights and displays worked great. From reading these forums, I knew I needed to turn off power management for anything usb rely and I did that before I did the flights. As I said before, they all worked perfectly. After the 2 big long flights I set up the controls for a few other planes , which worked great also. After I was finished for the night I went to bed and after work the next day, I came home and went to do a flight and all the controls worked as I set them up but no lights or displays. I have been working with as I learn and got the lights working for the Rp48 but no luck on the rest. Is there a way to reset and start over from the beginning? Maybe while I was poking around and learning how the software works, I might have changes a setting that caused my lights and displays to not work?
If they do light up OK, let me know.
I am on windows 11 if that makes a difference. My computer has 2 usb 2 on it and that’s where I have the go flights connected to. I do have the lights half way working on the RP48. None of the others light up when I click indentify. I’ll try the windos8fixer when I get home and let you know how it goes.
