FS2020 wbsim’s C172 no action in VC
With the change to MSFS I am starting to use the GF Interface Tools. After some reading, I thought to understand how to use it. However, when I config wbsim’s C172 with
RB48 R D0 Heading bug at rot 1 (inc/dec
RB48 R D1 Gyro drift + Kohlsman
166 1 Com
166 2 Nav
SECM
Nothing moves other than Com & Nav. But the status represents all my devices.
As a test I exported the device files one by one and imported it again, nothing. Next, I packed the .xml to a .zip file and imported the .zip. Same.
I tagged all the relevant devices (why not default = on?) and after status completed, I clicked the cancel? button. Correct?
Now I appreciate advice what I miss out to make Kohlsman and Co. acting according to the input in the C172 VC
  • edited October 2023
    One addition to my question: Could it be a Windows 11 issue? Some basic trials worked before changing from W10 to W11. Further I have no issues with W10 and P3D!
  • I don't understand this:
    Can you explain it better. E.g. what events you are using, actions etc.
    You can also use Detective and enable event monitoring. When you use the controls in the VC, Detective will show what events it is using. Failing that enable Lvar monitoring and see if you can set some lvars.
  • The problem was caused by a USB Hub. After exchanging it things work perfectly and the heading bug at the VC plus more move as expected.
    However, one thing would be nice: When importing a configuration, a click spot would select all devices.
    Thanks for your support.
    Guido
