November Build for X-plane reduces barometer to its minimum value
Hello,
Everything is in the title. Whenever I start GIT, barometer drops almost immediately to its lowest value (around 800 hpa) and stays there against any barometer knob input turn I can do.
Any suggestions or help ?
Thank you
  • Difficult to say. What hardware do you have that is configured to change the barometer?
  • I use RSG G1000 hardware and GoFlight hardware.
    Either one worked perfectly throughout the years with GIT but suddenly have this problem with the latest update.
    EDIT: Your question gave me a hint: as one button on my GF-RP48 was affected to the barometer setting, I changed it to something different. The problem is solved as the setting remains stable now. It seems the button itself is to blame.
  • Your button was probably sticking and causing the problem.
