FSX.ini file not found error when starting GIT2.1.13.0 P3D version
When starting GIT2.1.13.0, the P3D version, I get an error that the FSX.ini file could be found. I explicitely checked that I installed the P3D version, that is also shown in the title bar of the window.
Then, the log file also contains errors:
14:18:25 GoFlight Connection Starting.....
14:18:25 SimConnect Connection Starting.....
14:18:26 GoFlight Connection Started
14:18:26 SimConnect Message Processing Started
14:18:26 SimConnect Connection Started
14:18:26 Aircraft Connection Starting.....
14:18:26 FSX ini file not found
14:18:27 Aircraft Connection Started
14:18:27 Simconnect Version: 1.4.0.0
14:18:27 Synchronising Switches & Selectors .....
14:18:27 Synchronising Switches & Selectors: Waiting for Simconnect .....
14:18:29 PMDG SDK option is OK in Prepar3D
14:18:29 SimConnect: Event Received: Aircraft Type Changed
14:18:29 SimConnect: Event Received: SIM, 1
14:18:29 SimConnect: Event Received: PAUSE, 0
14:18:29 SimConnect Message Processing Finished
14:18:29 GoFlight Connection Starting.....
14:18:30 SimConnect Connection Starting.....
14:18:31 Synchronising Switches & Selectors Complete
14:18:31 GoFlight Connection Started
14:18:31 SimConnect Message Processing Started
14:18:31 SimConnect Connection Started
14:18:31 Aircraft Connection Starting.....
14:18:31 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
14:18:31 SimConnect: Event Received: SIM, 1
14:18:31 SimConnect: Event Received: PAUSE, 0
14:18:32 Aircraft Connection Started
14:18:32 Simconnect Version: 1.4.0.0
14:18:32 Synchronising Switches & Selectors .....
14:18:32 SimConnect: Exception Received: EVENT_ID_DUPLICATE
14:18:32 SimConnect: Exception Received: ERROR
14:18:32 SimConnect: Exception Received: NAME_UNRECOGNIZED
14:18:35 Synchronising Switches & Selectors Complete
Although everything seems to work fine.
Regards,
-Emile.
Hi Emile,
Just un-tick "Enable for FSX" in the Settings tab.
That's it. *blush*
-Emile.
