problem with software after update XP12.1BETA
I cannot get my MCP Pro to work since updating to XP12.1 Beta. 2 screenshots attached
same problem here, :'( can't work with new version Xplane
Even tried with a fully clean install after deleting the GIT software, plugin and deleting the Documents/Goflight Interface Tool folder. (yes, I rebooted the PC before installing the clean version.
Is still working fine in my XP 12.09 after the re-install.
Thanks by advance
Just came to see if this was addressed yet. Same issue here.
justin W
[0] = autobrake 1 = 0.125g
[1] = autobrake 2 = 0.155g
[2] = autobrake 3 = 0.225g
[3] = autobrake 3 = 0.4g
A quick workaround is to delete the above entries from the DataRefs.txt file located in your XPlane resources\plugins folder.
I will put out a release over the weekend that can ignore these incorrect entries, but for those wanting a quick fix, do the above.
thousands of thanks works perfectly now
Besten Dank für die schnelle Hilfe!
