Lua Non Operational! See GIT Log For Errors!
I get this LUA failure message quite often. From the LOG file, this appears to be the culprit:
WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27016
Full log file is at the bottom.
I have tried to set my current IP address: IPv4 192.168.1.11, however, this time doing so did not help. I disabled the Norton Smart Firewall and that did not help.
I resent my LUA.cfg file as follows:
hostname: 127.0.0.1
port: 27015
portms2020: 27016
path: default
luatimeout: 500
luahookcount: 3
dremimicmode: true
It was set to:
hostname: localhost
Any thoughts on how to get past this problem? It occurs in both the MSFS 2000 and XP12 version of GIT and just becoming a nightmare to work around .
Thanks,
Rich Boll
LOG File:
20:29:40 GoFlight Connection Starting.....
20:29:40 SimConnect Connection Starting.....
20:29:40 SimConnect Message Processing Started
20:29:40 GoFlight Connection Started
20:29:40 SimConnect Connection Started
20:29:40 Aircraft Connection Starting.....
20:29:40 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:29:40 SimConnect: Event Received: SIM, 1
20:29:40 SimConnect: Event Received: PAUSE, 0
20:29:40 SimConnect: Event Received: VIEW, 2
20:29:43 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27016
20:29:43 LUA Processor: Connect Exception - Unable To Connect!
20:29:43 Aircraft Connection Started
20:29:43 Simconnect Version: 11.0.62651.3
20:29:43 Aircraft FullName: flysimware_LEARJET_35A
20:29:43 Synchronising Switches & Selectors .....
20:29:44 LvarNamesUpdated!
20:29:44 Creating Bespoke Vars
20:29:44 Bespoke Vars Created
20:29:44 Importing Bespoke Variables
20:29:44 Bespoke Vars Assigned, Importing Bespoke Events
20:29:44 Bespoke Events Temp Imported
20:29:44 Bespoke Events Imported
20:29:44 Loading Aircraft Settings
20:29:44 GetXMLConfigData
20:29:44 GotXMLConfigData
20:29:44 Loading Power
20:29:44 Loading MCPPRO
20:29:44 Loading EFIS
20:29:44 Loading P8
20:29:44 Loading T8
20:29:44 Loading RP48
20:29:44 Loading MESM
20:29:44 Loading WP6
20:29:44 Loading LGT
20:29:44 Loading LGT II
20:29:44 Loading GF46
20:29:44 Loading GF45
20:29:44 Loading TQ6
20:29:44 Loading DIO
20:29:44 Loading GF166
20:29:44 Loading SECM
20:29:44 Loading Joysticks
20:29:44 Clearing Displays
20:29:44 Reset Data
20:29:44 Aircraft Settings Loaded
20:29:44 Calling Aircraft Changed
20:29:46 Aircraft Changed
20:29:47 BespokeEventProcessor: Task Failed RunLUA(C:\Users\richa\OneDrive\Documents\GoFlight Interface Tool\LUA\global.lua)
20:29:47 Global LUA Event Running
20:29:47 BespokeEventProcessor: Task Failed RunLUA(C:\Users\richa\OneDrive\Documents\GoFlight Interface Tool\LUA\flysimware_LEARJET_35A\global_aircraft.lua)
20:29:47 Global Aircraft LUA Event Running
20:29:47 Synchronising Switches & Selectors Complete
  • Can you see the FlightSimIoLua icon running in the notification area when GIT is running?
