W11 not recognizing GF-T8-2
Not sure what is causing the problem - the LED's on the toggle panel light up solid and W11 does not see the module (in a USB-2 port). Tried on 2 different PCs and my only guess is the board or IC chip is bad. The module did work at some point some time ago. Are there any contacts that can be 'jumped' to reset the board? Just wondering. My other T8 does work well with the polly software
