Error Code = 127
Hi, I install the software, everything was installed as it should, but I got the GIP: Pipe Connect Failed! error on the log of your app. On the XP9 log I see the: C:\X-Plane 9.70\Resources\plugins\GIT Plugin\win.xpl : Error Code = 127 : The specified procedure could not be found.
I have install all the dot net framework that I could find, OpenAL, also, but still the same issue, I'm using Windows 10 Pro 22H2.
What can I do, thanks!.
