GF-45
Hello
Can you help me please I've downloaded the interface tool for MSFS 2020 but I have been unable to get my two GF-45's to illuminate the interface is finding my GF-T8s and GF-P8s how can i tell if I need to download the GIT MSFS Module I have got my LGT ELEV Trim working and the landing gear but not the flaps
Roy
Roy
LED's And Displays Are Not Working
If you are running Windows 8 or Windows 10 and the LED's and Displays are not working, double check that you only have USB2 or USB1 ports connected to the GoFlight hardware. Note that ALL connections in between the GoFlight hardware and the PC must be USB 2 or USB1. If the problem remains, use Windows Explorer to go into the GoFlight drivers directory, right click on Windows8Fixer.cmd and select Run As Administrator. If this does not fix the problem, remove ALL GoFlight hardware and repeat; then reconnect the GoFlight hardware. Repeat this process until it all works. If the issue remains, try the hardware on a Windows 7 (or below) PC to check the hardware isn't faulty and if it is OK, contact GoFlight Inc for support.
