EFIS AND MCP MALFUNCTION
Hello
to date, the application has worked well under XP12 with GO Flight MCP PRO + EFIS hardware with ZIBO's abion B767. Today I installed the B737 from LEVEL UP and since then, nothing works properly The range button doesn't work the selection wheel for the APP VOR MAP PLN modes doesn't work either. I uninstalled everything and installed it again and it doesn't work. Can you help me solve the problem ?
Thanks in advance
Jacques
