General Sim Events and Settings
It sure would be nice to have a way to have a general set of settings not tied to an aircraft that would be automatically added to each aircraft file. For example I use the same button to pause and un pause the sim for every aircraft. There are several more but that is a good example. I guess you could use the Goflight program to do that but I was uncertain how it would work to have one or two buttons done via goflight and others on the same module being controlled by GFIT?
Would that work?
  • Hi Terry,
    Yes it would work. So long as you don't double assign (set something in GIT as well as GFConfig on the same control) then everything will behave as expected.
    I'll think about how I can modify GIT to allow a more general config approach.
