Variable change Backup
Hi Steve
I don't know what happened but all of a sudden the bespoke events I have been working on today had there variables change. The logic seems to stay the same but the variables and events changed to something else. For example I had one dealing with fuel pumps and they used Lvars and some std sim connect events. The Lvars changed to some gps Lvars and the events changed also. I have know idea what happened. I did reload the aircraft once? Luckily I noticed and was able to go back up the files before GFIT was closed. Which brings me to a question? Is there a way in the GFIT UI to cause a backup so that as you are working you could periodically backup as you are working?
Hi Terry,
Not sure what caused that issue. If you can provide the before and after xml configs and which aircraft you were using it will help me to track down any problem.
There is no automatic backup facility. Settings are saved if the aircraft changes or GIT is quit.
I had just over written the bad file with the backup when I got you post. By the way this happened a couple of times before today but I thought I had just screwed up and selected the wrong var but now that I think back it was probably this issue. I am working on the Realair Duke T V2 for P3D. I will pay close attention from now on and try to figure out the events that cause it.
I still think the backup idea is a good one. I had spent most of the day working on these and would not have wanted to lose that much effort.
