GIT does not transmit broadcast (numbers) from PMDG 737 in MSFS 2024 to the GF MCP PRO displays
I am able to send all button movements/presses from the GIT interfaced GF MCP Pro and GF EFIS to PMDG 737 aircraft in MSFS2024 , but the GF MCP PRO does not receive any information so the displays remain dark.
I have tried many things that did not work:
- change USB connection USB 2 or 1
- write the SDK broadcast message into the 737_Options.ini file,
- reinstall GF drivers (GFConfigSetup_2_28_0.exe) and GIT (GoFlightInterfaceToolMSFS_Setup_4_8_1_0.exe) into C:\\GOFLIGHT
- reinstall as administrator, run as administrator
- restart MSFS 2024, restart GIT, restart computer
- after enabling all GF units
does anybody have a solution? It seems that many users on this forum have the exact same issue since early 2025 and there is no solution...
Has PMDG changed something that can be fixed? I was convinced to buy a GIT tool that works for this common configuration.
Many thanks
Fred
Many thanks
Fred
LED's And Displays Are Not Working
