CTD XP12.4. b-3
Unfortunately, XP 12.4.b-3 still crashes with GIT plugin and running GoFlight software.
Threading violation calling XPLMCreateFlightLoop (C:\Users\Administrator\builds\eiafPmXpN\0\x-plane\design\SDK\COMMON\xplanesdk\Src\XPLM\XPLMProcessing.cpp:155)
Violation by GoFlight Interface Plugin (goflight.plugin - D:\XPlane12\Resources\plugins\GIT Plugin\64\win.xpl)
  • --EDIT--
    in XP12.4.b-4 the same behaviour CTD
  • No problem with the plugin on my end.
    I suggest backing up the airplane profiles and then un-install and reinstall a freshly downloaded plugin.
    If it loads fine after that you can place your profiles back.
    untick "update on flightloop" and "monitor private DataRefs" did the trick. Without re-install, anyway thanks for the suggenstion.
