Get COMM_ReceiverSwitches for PMDG737NGX
I would like to control RP48 leds based on the PMDG737NGX selector receivers. In the SDK I see the COMM_ReceiverSwitches[3] variables and the corresponding bitflags such as ACP_SEL_RECV_ADF1, and ACP_SEL_RECV_MKR. However, I have no clue how to accomplish this using GIT. I scrolled through the list many times but to no avail. Can you please help?
Thanks!
-Emile.
edit: to clarify: the buttons are attached to EVT_ACP_CAPT_REC_ADF1 and ..._MKR. That works perfect. Now I want the LED to light up when activated.
Hi Emile,
I will need to add some extra code to deal with flags since the value can be any combination of the flags it would be impossible to set GIT to light on a particular value.
I'll add it to the bug list.
Hi Emile,
The latest version of GIT now solves the problem you reported above.
Works like a charm! Thanks a lot!
-Emile.
Hi Kevin,
MOUSELEFT. ON_GREATER_THAN with a Light Value of 0 if you want it lit when its open.
