SECM
Hello Steve
Strange problem with the SECM and realair Duke. Some of the light switches like the taxi switch are sending out the programmed (I clicked use fs std) event only on the first throw. All subsequent throws send a single event? I can program the event (toggle taxi lights) to another T8 switch and it works properly. I have verified via dectective that the correct event is being sent but is being sent twice on first throw of SECM switch. I have tried different settings for the synch setting including totally of (no data) and they have no impact?
Problem solved. I had forgotten I was using parts of the SECM through the goflight config. I set that to compatible and all work.
