Issues with gift 2.1.14.2
Hello Stve
I have been away so I just updated to 14.2 today. I have a couple of issues so far. On one of my p8 units I was using the goflight config for some buttons. For example sim pause. These buttons no longer work now whereas they worked fine in the previous version. I have checked that the settings are still the same in the goflight config program.
Also the DIO image still doesn't show on my setup?
Continuing to test but wanted to get these to you now.
Hi Terry,
I've found and fixed the DIO bug. The P8 issue is odd - can you copy and past the log.
Did you uninstall the previous version?
No-one has reported anything. I still have your config so I'll try it with the A2A and P3D and come back to you.
Hi Terry,
The config files you sent me do not have any config data for P8 devices in them. Can you send them to me again?
That was the problem. The gui showed the correct settings for goflight config but when I looked in the file it was totally different. I saved to a new file and everything works. There is no problem with gfit for this issue.
Are you going to release a new ver for the DIO change? If not could you send me a beta to try.
I will release a new version today Terry, I was waiting for your feedback in case there was some more bugs to fix.
New versions for P3D and SE are available!
