2.1.14.3 Yellow light on Simconnect
i have managed to get GoflightInterfaceTool to work with X-plane, now i cant get the FSX-Steam edition to connect properly.
i have 2 xml entris in fsx
one is dll the other is exe
the dll goes like this
<?xml version="1.0" encoding="Windows-1252"?>
<SimBase.Document Type="Launch" version="1,0">
  <Descr>Launch</Descr>
  <Filename>dll.xml</Filename>
  <Disabled>False</Disabled>
  <Launch.ManualLoad>False</Launch.ManualLoad>
  <Launch.Addon>
    <Name>Object Placement Tool</Name>
    <Disabled>True</Disabled>
    <ManualLoad>False</ManualLoad>
    <Path>..\Microsoft Flight Simulator X SDK\SDK\Mission Creation Kit\object_placement.dll</Path>
  </Launch.Addon>
  <Launch.Addon>
    <Name>Traffic Toolbox</Name>
    <Path>..\Microsoft Flight Simulator X SDK\SDK\Environment Kit\Traffic Toolbox SDK\traffictoolbox.dll</Path>
  </Launch.Addon>
  <Launch.Addon>
    <Name>Visual Effects Tool</Name>
    <Path>..\Microsoft Flight Simulator X SDK\SDK\Environment Kit\Special Effects SDK\visualfxtool.dll</Path>
  </Launch.Addon>
  <Launch.Addon>
    <Name>GoFlight Module Interface</Name>
    <Path>C:\Program Files (x86)\GoFlight\FSX-SE\GoFlight Interface Module.dll</Path>
  </Launch.Addon>
</SimBase.Document>
and the exe
  <Filename>EXE.xml</Filename>
  <Launch.ManualLoad>True</Launch.ManualLoad>
  <Launch.Addon>
    <Name>Addon Application</Name>
    <Path>C:\MyPath\Addon.exe</Path>
    <CommandLine></CommandLine>
    <NewConsole>True</NewConsole>
  </Launch.Addon>
  <Launch.Addon>
    <Name>GoFlight Hardware Interface</Name>
    <Path>C:\Program Files (x86)\GoFlight\GFDevFSX.exe</Path>
  </Launch.Addon>
</SimBase.Document>
what am i doing wrong here
  • edited August 2015
    this is the Git Log when fsx-se is finished loading
    23:36:05 GoFlight Connection Starting.....
    23:36:05 SimConnect Connection Starting.....
    23:36:06 GoFlight Connection Started
    23:36:15 SimConnect Message Processing Started
    23:36:15 SimConnect Connection Started
    23:36:15 Aircraft Connection Starting.....
    23:36:16 SimConnect: Event Received: Start
    23:36:16 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    23:36:16 SimConnect: Event Received: SIM, 0
    23:36:16 SimConnect: Event Received: PAUSE, 0
    23:36:16 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:16 Aircraft Connection Started
    23:36:16 Simconnect Version: 10.0.62613.0
    23:36:16 Synchronising Switches & Selectors .....
    23:36:16 Synchronising Switches & Selectors: Waiting for Simconnect .....
    23:36:28 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    23:36:35 SimConnect: Event Received: Aircraft Type Changed
    23:36:35 SimConnect Message Processing Finished
    23:36:35 GoFlight Connection Starting.....
    23:36:35 SimConnect Connection Starting.....
    23:36:36 GoFlight Connection Started
    23:36:36 SimConnect Message Processing Started
    23:36:37 SimConnect Connection Started
    23:36:37 Aircraft Connection Starting.....
    23:36:37 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    23:36:37 SimConnect: Event Received: SIM, 0
    23:36:37 SimConnect: Event Received: PAUSE, 1
    23:36:38 Aircraft Connection Started
    23:36:38 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:38 Simconnect Version: 10.0.62613.0
    23:36:54 SimConnect: Event Received: SIMSTART, 0
    23:36:54 SimConnect: Event Received: SIM, 1
    23:36:54 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:55 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:56 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:57 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:58 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:36:59 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:00 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:01 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:02 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:03 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:04 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:05 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:06 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:07 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:08 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:09 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:10 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:11 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:12 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:13 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:14 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:15 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:16 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:17 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:18 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:19 SimConnect: Exception Received:  OUT_OF_BOUNDS
    23:37:21 Synchronising Switches & Selectors Complete
  • I get this in P3D also, i have taken a complete reinstall once again, i have followed youre instructions in the guide/faq but nothing seems to work, GFDevp3d.exe starts up as it should but i have 2 of 3 greens,
    exe.xml seems fine as the GFDevp3d.exe starts up, GFT is using Simconnect 1.4.0.0, i have installed the Simconnect from the p3d folder and rebooted but im on the edge of giving up, i recently bought a complete Goflight Airline stack and really need this to work.
    is there any way to get GFT to use an other version of Simconnect.
    bytheway i use p3dv2  2.5.1.2946.0
    maby p3dv2 isnt supported
    frank
  • It's the GoFlight Interface Module.dll that is used in GIT, the other stuff is GoFlight software which GIT doesn't use. If you are seeing this in all versions I would rename My Documents\GoFlight Interface Tool to eliminate any corrupt files.
    I'm also concerned about this line:
    All GIT software should be installed in C:\Program Files (x86)\GoFlight\ and not a subdirectory of it which you have used (FSX-SE)
    Did you get a prompt when running flight sim about the GoFlight Interface Module loading?
  • i have given up on fsx-se, im guessing that p3dv2 is my last hope.
    <?xml version="1.0" encoding="WINDOWS-1252"?>
    @namespace html url(http://www.w3.org/1999/xhtml); :root { font:small Verdana; font-weight: bold; padding: 2em; padding-left:4em; } * { display: block; padding-left: 2em; } html|style { display: none; } html|span, html|a { display: inline; padding: 0; font-weight: normal; text-decoration: none; } html|span.block { display: block; } *[html|hidden], span.block[html|hidden] { display: none; } .expand { display: block; } .expand:before { content: '+'; color: red; position: absolute; left: -1em; } .collapse { display: block; } .collapse:before { content: '-'; color: red; position: absolute; left:-1em; } <SimBase.Document version="1,0" Type="Launch"><Descr>Launch</Descr><Filename>EXE.xml</Filename><Disabled>False</Disabled><Launch.ManualLoad>False</Launch.ManualLoad><Launch.Addon><Disabled>False</Disabled><Name>GoFlight P3D Data Bridge</Name><ManualLoad>False</ManualLoad><Path>C:\Program Files (x86)\GoFlight\GFDevP3D.exe</Path><CommandLine/></Launch.Addon></SimBase.Document>
    this is my exe.dll in p3d, and im not getting a warning when starting the game
    <?xml version="1.0" encoding="Windows-1252" ?>
        <Launch.Addon>
        </Launch.Addon>
    </SimBase.Document>
    this is my exe.dll in p3dv2.5
    frank
  • <?xml version="1.0" encoding="Windows-1252"?>
      <Launch.Addon>
        <Name>FSUIPC 4</Name>
        <Path>Modules\FSUIPC4.dll</Path>
      </Launch.Addon>
      <Launch.Addon>
        <Path>C:\Program Files (x86)\GoFlight\GoFlight Interface Module.dll</Path>
      </Launch.Addon>
    </SimBase.Document>
    it seems that i got it working, dll.xml instead of exe.dll,
    ps! check out our 70-80s inspired neo/progrockband TerraMater on facebook :-)
